-   -   does the sump plate use regular washers or sealing washers ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/911761-does-sump-plate-use-regular-washers-sealing-washers.html)
theiceman 04-25-2016 08:03 AM
cant quite make it out in Waynes book .
my original setup on my 78 sc is looking like regular washer, spring washer regular nut. I was going to put on yellow zinc nyloc with a yellow zinc flat washer for that nice finished look but then wondered if I am supposed to be using some kind of aluminum sealing washer like the valve cover guides.
Thanks in advance.
Steve@Rennsport 04-25-2016 08:38 AM
Aluminum sealing washers.
theiceman 04-25-2016 08:51 AM
Thanks Steve .
the project continues ......
prschmn 04-25-2016 07:10 PM
The sealing washers aren't needed if the studs are loctited-they just prevent leakage past the threads. I'd say use whatever you think is prettiest-is that word?
Henry Schmidt 04-26-2016 04:04 PM
We use a very thin coat of Curil T on both sides of both gaskets and large diameter steel washers.
The sealant prevents leakage and the larger washers prevent sump cover deformation.
Just another thought.
http://forums.pelicanparts.com/uploa...1461782188.jpg
KTL 04-28-2016 07:26 AM
Get a box of nyloc flange nuts and make the nuts & washers one with each other. :D
http://forums.pelicanparts.com/uploa...1461853537.jpg
Box of 50 yellow zinc class 10 (overkill) is $9 or a box of 100 white zinc class 8 is $5.37
theiceman 04-30-2016 07:24 PM
damn you guys .... if I only had one choice life would be easy :)
