help Rocker arms question
hi, we have a problem with the final tuning of my engine
i have a 2.0T engine and we did the 2.2S P&C upgrade with also 2.2-2.4 heads i bought E cams and now we have a problem tuning the rocker arms....... it looks like if the srew of the rocker arm is to short to tune it for the exhaust valve !! i do not remember having seen something writen about a change to do to the rocker arms for this upgrade ... any ideas ??? cheers steve |
Were these reground cams? If so then the base circle is reduced-or the stem height
of the valves is short. There used to be cheapo cams out there that had a too small base circle. Not really safe to use as it throws the geometry off. |
My mechanics says he would need 5mm more on the exhaust valve.... Could it be that the valve is to short? I bought the heads with new valves put in place...
5mm is a lot :confused:
You could use lashcaps. |
I assume the rocker arms were ground/resurfaced? Could it be that too much was taken off the pads?
Thanks friends, we took a Head out and checked !!! The exhaust valve is 6mm to short...... So ordered 6 new ones
Thanks to all for the help |
| All times are GMT -8. The time now is 04:18 AM. |
