Slippery Slope Expert
Steam Driver's Avatar
Pre-Filling Carrera Tensioners
I have gone through the procedure to pre-fill the tensioner bodies outlined in the tech article, but when I was doing so I noticed no air bubbles exiting from anywhere. Is this normal?
Also, thinking about it, this is a good exercise, but there can still be air introduced into them on start-up because the oil lines feeding the cam boxes will initially be full of air that has to go someplace.
Old 04-26-2016, 03:18 PM
I pump them up just to be sure they pump up. That also keeps some tension on the chains for the short time it takes for the lines to fill.
206 637 4071
Old 04-27-2016, 06:37 AM
