-   -   Tensioner and Idler Arm Interface (http://forums.pelicanparts.com/911-engine-rebuilding-forum/912042-tensioner-idler-arm-interface.html)
Steam Driver 04-27-2016 09:52 AM
I installed my chain tensioners last night, but didn't "pull the pin." I noticed that the idler arm didn't rest on the center of the tensioner plunger and am wondering if this is a concern. The car is an '82 SC, and should have the updated idler arms. See images:
http://forums.pelicanparts.com/uploa...1461775901.jpg
http://forums.pelicanparts.com/uploa...1461775932.jpg
Flat6pac 04-27-2016 11:19 AM
The idler arm is the updated one.
You have a flat surface on the tensioner but there is a curved surface on the arm to adjust for expansion from heat and wear of the chain
Everything is good
Bruce
Steam Driver 04-27-2016 01:23 PM
Thanks for the input. I was concerned that the idler arm foot should be more centered (fore and aft) over the plunger.
Flat6pac 04-27-2016 03:30 PM
Your idler has a couple mils of in and out movement. Tensioner is fixed, idler isn't.
Bruce
