-   -   Gap in late style 930 tensioners with late style idler arms (http://forums.pelicanparts.com/911-engine-rebuilding-forum/912222-gap-late-style-930-tensioners-late-style-idler-arms.html)
wprater 04-28-2016 03:40 PM
On my left bank, the idler arm has lateral freedom when the tensioners is installed. I'm using the correct thin boss tensioners with the later style double bushing indeed arms.
I should not need a spacer because of this, but perhaps my chain case has an issue? Do I need to add some washers on the other side?
Here is a picture showing the gap, I can push the idler arm forward to meet with the tensioner and it will be flush. However, then there is a gap in the rear. Is this an issue while the car is running? Will the chain rails keep them aligned?
https://www.dropbox.com/s/bo6bopob4v...peg?dl=0&raw=1
Henry Schmidt 04-28-2016 04:04 PM
Self aligning feature. No worries.
wprater 04-28-2016 04:11 PM
Thanks, Henry!
