-   -   Engine stand (http://forums.pelicanparts.com/911-engine-rebuilding-forum/913364-engine-stand.html)
outsider347 05-07-2016 05:12 PM
Engine stand
I am in the info gathering, parts price comparison stage of a 79 911 3.0 rebuild
Thinking that this will probably be my only Porsche engine adventure.
Question is. If I buy the 300.00 engine stand offered for sale here, would it be easy/difficult to sell the used engine stand when I am done?
what would be a fair sell price
Thanks Gents
ed
0396 05-07-2016 07:15 PM
I think your referring to the engine yoke. Often referred to as p201. I currently have a 4 arm Baum unit and just bought a 5 arm Baum engine yoke.
The 4 arm came out years ago when the engine was say 350 lbs. Now with something like the 964 / 993 engines, I rather upgrade to the latest 5 arm Baum units.
Back to your question, quality tools are always in demand. Just surf the classified and you will notice they usually don't last long. Good luck with build.
outsider347 05-07-2016 07:22 PM
Yes correct the P201 yoke
Kind of what I was thinking...thought I'd ask here first.
Tks 0396
strictly 05-08-2016 01:24 AM
i think you will have no problem selling it, someone will always want it. It will work for a gearbox too. Definatly get the P201 (everyone will always pay for quality), i use it with a sealey 550kg stand in a U shaped configuration not the T shaped one which can fall over. The sealey 550kg is a UK brand, the yoke is 60mm
SoyRacer 05-09-2016 04:40 PM
I can always use another . . . and I'm local.
LMK
RR
Flat6pac 05-09-2016 05:57 PM
Soy, Orchard Park is just south of Buffalo..not local to the island
Bruce
Gene Smith 05-09-2016 06:13 PM
Question: When using 4, 5 ,8,9, 11 arm engine stands is there any upgrade of the two small transmission bolts holding the engine from peril? I just redid my engine and the 4 arm stand was very up to the job. But it was a Mg 2 liter...
JJ 911SC 05-09-2016 07:15 PM
From a few years back,
Originally Posted by JJ 911SC (Post 8478217)
If you got the real engine yoke (P201), it's the lip that hold the engine and the 2 nuts only hold the ring tight to the engine flange.
Gene Smith 05-09-2016 07:25 PM
Yep the lip fit tight against the engine ridge. Two bolts... Nerve wracking.
JJ 911SC 05-09-2016 07:30 PM
Originally Posted by Gene Smith (Post 9113772)
... Two bolts... Nerve wracking.
Yes, I had the engine on the wall for 3 months but I put my lift table under it when I was not working on it.
0396 05-09-2016 07:48 PM
I've know of an individual that stores his spare 993 vram hooked up to a Baum on a stand..so he can move it around the garage for the past 4 years.
Emo993 05-10-2016 10:00 PM
+1 on the P201 Yoke....then build or buy a quality engine stand like this. Easily holds a 930 turbo, a copy from Jerry Woods shop.http://forums.pelicanparts.com/uploa...1462942729.jpg
fred cook 05-11-2016 01:07 PM
5 arm engine yoke
Outsider,
I have a 5 arm engine yoke that has been used twice that I would sell. It was used once to rebuild a 993 engine and once for a 3.0 rebuild. Send me a PM and we can discuss terms!
Thks,
Fred Cook
outsider347 05-16-2016 07:17 AM
Originally Posted by fred cook (Post 9116156)
Outsider,
Thks,
Fred Cook
Oh man. Story of my life....
Just bought one
911pcars 05-20-2016 10:49 PM
For max stability, the engine stand should have 4 legs/wheels.
Sherwood
