Need help identifying 3.2 main bearings
Does anyone know what the replacement part number is for 930.132.61? I'm pretty sure they're standard inner dia / .25mm outer dia
any info would be appreciated |
It would be very unusual to have a 3.2 case linebored oversize-have you measured the bore?
I don't have a bore gage but I did measure the old bearings and new bearings with a caliper. Putting the bearings mated together and then measuring the I.D. / O.D. / & thickness of the bearing...it all points to a .25mm larger O.D.
I was hoping someone would confirm the old part number and then offer up the new part number |
Are you sure the number doesnt have a 101 after the 930? The part number is too short.
If those are available be prepared for the price-won't be cheap |
Item 18: Porsche Crankshaft (102-00) NLA on PP but they where $100 x 12 |
| All times are GMT -8. The time now is 10:57 PM. |
