-   -   HArd cross over oil line issue (http://forums.pelicanparts.com/911-engine-rebuilding-forum/913842-hard-cross-over-oil-line-issue.html)
theiceman 05-11-2016 09:14 AM
Hey Gents
As part of my rebuild I got an aftermarket hardline that goes from the engine case and fastens on to the passenger side timing chain box.
Well the one I got has no bracket to fasten to the timing box. Not a big deal as I can put on a clamp easy enough, but when I went to install it I realized it is not even close the the bottom of the timing box , although its close when overlayed on the other pipe I realized im a good two inches towards the back of the car. Anyone ever run into this ? I was just going to go to a pipe bender guy and ask him to bend it in a little more as the oil connection is a mid air connection anyway. I think currently it might not even reach my oil coupler in the car .
Any thoughts ?
theiceman 05-11-2016 09:29 AM
okay did a little more research and realized my mistake .. I ordeed the wrong on .. I ordered the turbo one by accident .. gonna see if I can bend it a little more and use it if it doesn't interfere anywhere.
Flat6pac 05-11-2016 09:46 AM
The turbo pipe that you bought has a bend around the kidney of the turbo. The pipe from right corner to the thermostat should be the same as the SC and turbo that drops a rubber hose at about 45 degrees to the new connecting pipe.
Bruce
theiceman 05-11-2016 11:43 AM
Thanks Bruce , it looks close but when I bolted it on it sticks out behind the timing cover by about 2 inches , im thinking a bit more bend is in order .I wll try and post a pic.
Flat6pac 05-11-2016 01:07 PM
There is a lot of lever there, be careful not to crimp it
theiceman 05-12-2016 04:24 AM
I'm going to try and use a conduit bender and some heat. What could possibly go wrong :)
I figured I have the old one as a backup
theiceman 05-12-2016 05:44 AM
Bruce et All
I little bending is in order for this line ? im thinking it should line up with the timing chain case .http://forums.pelicanparts.com/uploa...1463057074.jpg
http://forums.pelicanparts.com/uploa...1463057084.jpg
wprater 05-12-2016 10:15 AM
where did your exhaust studs go?
theiceman 05-12-2016 08:03 PM
Not installed yet intentionally
BoxsterGT 05-13-2016 06:38 AM
Watching this thread, as I have seen these issues before.
Cut & weld and then re-plate has been my method when these oil pipes do not fit.
http://forums.pelicanparts.com/uploa...1463146679.jpg
Len
theiceman 05-14-2016 10:25 AM
update .
I did a test fit ( and glad I did ) . The reason the pipe does not come close to the timing cover is because the initial bend out of the case is not correct. the reason I know this is the pipe hits the heat exchanger when I install it . I either cant install the pipe. of the exchanger on the side where the pipe goes into the case. If the pipe took a true 90 degree angle where it came out of the case it would not interfere with the exchanger and be tucked more so it would align with the exchanger.
I attached a pic but i'm not sure if the pic shows its not quite at 90 degrees.
My buddy is going to re-weld the bracket that broke off my original pipe and i'm just going to use that . I might take this pipe to a hydraulic shop and see if they can bend it a little more at that point. Nothing to lose at this point, and i'm just curious as to whether I can get it to fit.
( just to be clear I did NOT buy tis part at our host !! )
http://forums.pelicanparts.com/uploa...1463246692.jpg
911 Rod 05-16-2016 08:55 AM
You could also just have a flexible line made up at a hydraulic shop.
