Need a Part Number for Wrist Pins
I purchased a set of 2.4 S pistons without wrist pins. The PET only shows a part number for the cylinders, pistons, rings, wrist pins and circlips as a set, no individual part numbers for 72-73 engines. I found a set of wrist pins for 74-77 engines with a part number of 091110332100. Will these work?
Thanks,
Greg
Old 02-25-2018, 11:36 AM
VFR750's Avatar
JE pistons sells piston wrist pins separately. I needed one because of a scratch.
Call them up. They sell new pistons for 2.4 so they should have wrist pins that match your rod small end.
Old 03-07-2018, 02:54 PM
