Need help and advice in 3.3L short stroke engine build
Hey Guys, My car is a 1981 911SC with the stock 3.0L. I have seen tons of info on the 3.2SS build but not much on the 3.3L. I have no HP goals set in mind and hope to not over build the car buy making it unpleasent for daily driving. I will list my build plans below and hopefully you guys can chime in on any wrong doings.
I have aquired a set of 100MM P&C's Pistons are JE 10:1 compression ITB's with CoilPacks, EFI, and MegaSquirt will run it all. Camshatfs are undecided thinking DC-40 or somethings like it. Advice? As of now, I plan to keep my stock heads and port match them to the gaskets. Advice? No plans for Twin Plug but I do have a set of 3.2 heads if bigger ports are nessary. Advice? My car already has a Bitz-EZ-EFI kit, turbo valve covers, APR Head Studs, 3.2 timing chain tensioner, Dual Oil Coolers, headers, and 2 in, 1 out, exhaust system already on the car. Car runs excellent but I'd like more power. Thanks in advance! |
everything Ive found in the research for my SC indicates anything over 9.5:1 without great gas (read: 100 octane) requires twin plug or you're having to pull so much timing you lose power...
curious what coil packs are you going to go with and how you will trigger the MS - Im doing a similar setup but dont have the blitz and dont know if it comes with crank and/or cam triggers? |
I've bought my coil packs from dyiautotune.com along with the signal trigger. They are extreemly helpful and quick to reply via email. They have everything you'll need to get the job done and your engine running right. |
yup, Ive read those as well. Have you seen this? this is a good thread with pretty much all the big brains in it :)
fwiw the way I read it is that a 100mm cylinder is borderline "excessively large" and 10:1 is high Quote:
Its a different Steve but still a smart Steve ;) Quote:
| All times are GMT -8. The time now is 12:30 PM. |
