888 888 is offline
91 3.3 crankcase bore out for 100mm Barrells ?
Hi I'm thinking of purchasing a set of QSC barrels & pistons plus rings as a set there to replace worn out piston lands & I believe that the crankcase will need to be bored out from original size 97mm to 100mm, is that correct, I'm new any help would be greatly appreciated.
Frank
Old 06-05-2016, 06:02 AM
Yes to accept the larger jugs. I would use ollies for your machine work. They have a media tumbler to clean your case and make it look like it just came from the factory. They are the best.
Dan
Old 06-05-2016, 07:07 AM
