-   -   2.2 S & 2.4 S piston specs info.. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/916623-2-2-s-2-4-s-piston-specs-info.html)
Luke M 06-02-2016 11:15 AM
Does anyone have or would know where I could find the 2.2 S & 2.4 S piston specs ?
Looking to see if the pistons that I have are within spec.
I tried google search on this and didn't find any usable info.
Any info would be greatly appreciated.
Thanks,
Luke
Flat6pac 06-02-2016 11:45 AM
I believe it's in the small handbook. If you can glass bead the face of the piston there is a stamping telling the new casting size, like 83.97.
Bruce
Luke M 06-02-2016 12:16 PM
Bruce
Hi Bruce,
I was able to locate my tech book. I found the group size on the piston but nothing like the actual o/d. The tech book states 83.95 + or - .005 . The piston groves are throwing me off. The numbers that I'm getting don't jive with the book. It could be the tool that I'm using to measure the grove with too?
archnraft 06-04-2016 09:29 AM
Curious to know the answer to this thread as well regarding 2.4S pistons "in spec" range :)
Trackrash 06-04-2016 08:34 PM
Originally Posted by Luke M (Post 9144955)
Hi Bruce,
According to the book the ring side clearance (wear limit) is .2mm. Which is ~.008".
I would not use a piston that had .004" ring side clearance or more.
Install a new ring and try to fit a .004" feeler gauge beside the ring.
