-   -   2.7l head used on a 2.4l engine???? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/918603-2-7l-head-used-2-4l-engine.html)
turbo930ss 06-17-2016 05:41 PM
Can I use a 2.7l head casting number 911.104.342.2R on a 2.4l engine with heads with casting number 911.104.302.0R. ? The 2.7 head seems to measure the same. I have one bad cylinder on my race engine. This is a turbo charge engine with enlarged ports.
Thanks Scott
prschmn 06-19-2016 06:48 PM
I think-you can and will
john walker's workshop 06-19-2016 08:18 PM
The 2.7 outer bevel in the chamber makes the sealing surface almost nil. That's the area toward the inside of the sealing ring on the cylinder. 2.4 on a 2.7 ok, but not VV.
