Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
Cam choice oppinions?
Hello, I'm building a motor based on an 3,0 SC motor. And I would like some expert opinions on my cam choices. I know this has been discussed, but would still like to hear experiences and recommendations from you all.
Motor specs:
3,0L
Heads, '78 SC 39mm intake ports
Ignition, Single plug, re-curved SC distributor
Pistons, JE 9.5 to 1
ARP rod bolts
CR, 9,7 to 1
Carbs, 40mm Webers
Exhaust, '71 stock w/sport muffler
Transmission, '72 915, stock gears
Car, 71 911, 2300 lbs, with driver
Use, 75% AutoX, 20% DE
91 octane gas
I am after a broad flat torque curve. Not necessarily the ultimate in high end HP. My normal shift point would be 6500RPM, but would want to be able to go to ~7200RPM to save a shift.
I am thinking something along the lines of a DC 35, DC 40, or DC 43.
Thanks,
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-20-2016, 01:29 PM
Gordo2's Avatar
Give DRC A Call
Gordon,
Give John a call - I had similar goals and a similar build. He recommended the GT-2 102 cam profile.
Couldn't be happier, torque comes on at a much lower RPM range as compared to stock (~185 ft lb @ 3,500 RPM equals neck snapping acceleration).
Dyno Results - Gordo's 3.2L
Good luck,
Gordo
Don Gordon "Gordo"
'83 911SC Targa
'87 FJ-60 TLC
Old 06-20-2016, 08:05 PM
Under the radar
Trackrash's Avatar
I was just re-reading your post. It is exactly what I am looking for. I see the GT2 turbo on his site, is that the one?
I have sent Dougtery.com two requests for info, but have not heard back. Thus my post. I guess my next step is to get on the phone if he doesn't chime in.
Gordon
Old 06-20-2016, 09:03 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
He's camgrinder here on the forums if you want to send him a private message.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 06-21-2016, 10:11 AM
Puny Bird
Mark Henry's Avatar
Web 120/104 would also be a good choice. Hot street and club racing, good idle and torque.
'74 Porsche 914, 3.0/6
'67 Bug, 2600cc T4
'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 06-21-2016, 11:16 AM
Schleprock
KTL's Avatar
I was going to suggest those too. I have them in my racecar's engine and so did a friend in his 3.3L short stroke racecar engine.
Kevin L
Past: '87 Carrera
Old 06-22-2016, 07:23 AM
Under the radar
Trackrash's Avatar
I was told Web cam was the way to go.
What springs, retainers, rockers are you using and what is your red line?
Thanks,
Gordon
Old 06-22-2016, 10:44 AM
Schleprock
KTL's Avatar
I have EBS Racing's springs and Ti retainers and so did the 3.3L Original rockers refurbished with cgarr's low friction bushings. Redline is 7500. Both cars had Weber 46. Mine was a 3.2 short stroke
Kevin L
Past: '87 Carrera
Old 06-22-2016, 11:40 AM
Under the radar
Trackrash's Avatar
What is your maintenance schedule for your TI retainers? Do you ever replace them?
Gordon
Old 06-22-2016, 05:23 PM
Schleprock
KTL's Avatar
Not sure what a projected time-out is for the springs and retainers. My engine build is rather mild, so I planned on 120+ hours of sustained track driving.
Henry @ Supertec or chris_seven @ Fenn Lane would have a better answer than me!
Kevin L
Past: '87 Carrera
Old 06-23-2016, 06:54 AM
