1979 930 wrist pin circlips?
I've spent an hour trying to find these on here, does anyone know where they are? Called the 800 number 3 times, tired of the elevator music. Thanks in advance.
Old 03-22-2016, 01:02 PM
Thanks for the reply but that is a transmission retainer clip.
Old 03-22-2016, 02:03 PM
Found them on another site. I'd like to give these guys my business but I'm not spending an hour on the website and another 20 min on hold for $3 of parts.
Old 03-22-2016, 02:06 PM
EBS has them
Old 03-22-2016, 02:12 PM
VFR750's Avatar
I'm assuming searching under "wrist pin clip" did not result in finding them in 10 seconds, like it did for me just now?
Old 03-22-2016, 02:14 PM
You must be on another pelican site than I am. I put in wrist pin clip and wrist pin circlip. The first thing that comes up is the Stomski tool and lots of other circlips but nothing that goes in a piston. Either that or I am blind.
Old 03-22-2016, 02:26 PM
VFR750's Avatar
Sometimes I skip the part where you say what year and model. Seems the search results can be broader. That might be it.
Old 03-22-2016, 02:53 PM
https://www.************.com/p-1677-wrist-pin-circlip.aspx?keyword=wrist+pins
I could not find them here either... but a simple google turned these up
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 03-22-2016, 03:44 PM
That's the wrong size for a turbo.
Bruce
Old 03-22-2016, 04:10 PM
VFR750's Avatar
Use "clip" not "circlip"
This says it's ok for 79 turbo
Old 03-22-2016, 05:24 PM
82 911 would use 22mm. Turbo from 78 uses 23mm clips.
Bruce
Old 03-22-2016, 05:37 PM
VFR750's Avatar
Does it matter? This is a spring clip.
It is much larger than 22 or 23 mm in free state diameter. 1mm less compression shouldn't make a difference.
Old 03-22-2016, 05:42 PM
I wouldn't think it would make a difference but I wonder why the 22 mm one didn't pop up for the turbos?
Old 03-22-2016, 07:18 PM
VFR750's Avatar
I think sometimes the filter for year and model exclude too many parts.
If you search under my 82sc, and then go into "more info" you should see the list where the part fits other models. Yours is listed there.
Old 03-23-2016, 02:44 AM
Ah ha, you cracked the code, thanks!
Old 03-23-2016, 04:48 AM
The big ones are heavier wire on some applications. Order for the size of the pin bore.
206 637 4071
Old 03-27-2016, 09:31 AM
Amen
Bruce
Old 03-27-2016, 12:10 PM
I guess I'll see what I end up with when I get the Pelican order. I kept the old ones so will compare the new to old. I saw no reason to remove the original clips on one side so ordered eight to allow for two disappearing into never-never land during installation.
Old 03-28-2016, 07:18 AM
Thought I'd update this. Went to put the cylinders/pistons on tonight and I compared the circlips that i bought (N-012-278-1) to my old ones that came out. The OD of the new ones is smaller than the ones that came out. Old ones measure 26 mm ( for 23 mm pin) , new ones are 25 mm (for 22 mm pin) . The correct part number for the 23 mm pin clips like on the '79 930 is 900-908-019-00. They are called "circle clips", go figure. Would the aftermarket 22mm clips work, I don't know but I'm not using them. Pelican, describe these correctly as "circlips" so they show up in a search!!
Old 06-26-2016, 07:17 PM
