Efi
I was wondering if anyone had ever added a TPS to the single throttle body used on a K Jetronic of is everyone was using the TPS emulator by using a vacuum connection to a Megasquirt?
I was using my stock throttle body on my 930, check here post #14:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/580883-another-efi-conversion.html Guess same solution possible for any single TB... |
As long as it has a D shaft and a mounting point you can make it work.
SDS sells a simple TPS to mount. They have two models one CW the other CCW. I changed TB's and the CCW I had was easy to drill through and carefully file it open and I just flipped it over for CW. |
Mine did not had a D-shaft, but the TPS is available as early version incl. shaft:
TurboKraft Inc : Thottle Position Sensor Set - Early Models [930 606 113 TK] - $188.00 or the late version without shaft: http://turbokraft.com/catalog/product_info.php?products_id=145 |
I used a 3.2L intake which has its own D shaft. A 3/8" spacer is required to move properly position the TPS. The TPS is the same one that SDF sells and the spacer is 3/8" phenolic shaped on a table saw. I patterned mine from Jim2, but he used aluminum for his spacer.
http://forums.pelicanparts.com/uploa...1467423156.jpg |
Yes that is the same one I have except mine is grey, I think the grey one is CCW and the black is CW.
But if you got the wrong one you can carefully cut a hole in the center of the circle and flip the TPS over to work the other direction. |
Mark - I love it - I've had problems with the TPS on my TRW intakes (like the resistance dropping as you open the throttle, then finally increasing), and the official replacement (for a German Ford or some odd model) is a bit pricy. Looks like a guy can just get creative. The Electromotive programming will adjust to give a linear response by zeroing at closed and WOT, so the values maybe don't matter all that much.
Use a mid-90's BMW of any model except 318i.
I have a 95 325i one on my 3.2 TB. |
Turbokraft sells kits for this. Plug and play
David |
David: oh, to have received this gracious offer in 2011 when I made this! Thanks for the great offer, but this has been running quite well and shows no signs of deterioration. The phenolic is quite sturdy -- I was really surprised how hard it is and how tough it is on saw blades. In this application, it is not subject to bending stress or heat. Brian
Cool Brian :)
| All times are GMT -8. The time now is 08:50 PM. |
