-   -   What the Heck is this and did it come from the Engine? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/920532-what-heck-did-come-engine.html)
DRACO A5OG 07-04-2016 06:54 AM
:confused:
So I was preparing to install my D-side cams and after I removed my Carrera oil line from over the chain box to the cam tower. I started to clean the area and found this weird thing just sitting at the bottom of the #3 rocker/valve port.
WTF?
http://img.photobucket.com/albums/v5...psr6py0cwd.jpg
http://img.photobucket.com/albums/v5...psnyvwhmwq.jpg
http://img.photobucket.com/albums/v5...psx3jfifok.jpg
http://img.photobucket.com/albums/v5...psdwsyij8u.jpg
Is this part of the engine? I can not imagine PAG would use plastic inside the engine, right?
I tried to fit it into the banjo bolt thinking it was some sort of innerds of a check valve??? Nope, no fit.
I was working on my step-son's Infiniti, maybe it dropped and bounced into the engine? I was pretty careful but poop does happen :eek:
TIA fellas,
Jim
Heinz911 07-04-2016 10:03 AM
Dowel pin of some sort. The cam-shaft to sprocket one should be 6mm in diameter and the nr.8 bearing should be 8mm. So it is not one of the obvious.
DRACO A5OG 07-04-2016 11:38 AM
Both cam pins in place
Did not split case.
I think it is an errand tool or debris from the Infiniti ��
Flat6pac 07-04-2016 01:23 PM
The pin that holds the #8 nose bearing in place
Bruce
DRACO A5OG 07-04-2016 01:42 PM
It's plastic?
But how the heck did it get there with case not being split ?
Mark Henry 07-04-2016 01:51 PM
Originally Posted by DRACO A5OG (Post 9185836)
It's plastic?
No, it wouldn't be plastic. I'd say it's not from the engine.
Good thing it's not in the engine anymore right? ;)
DRACO A5OG 07-04-2016 01:53 PM
http://www.pelicanparts.com/catalog/...06100-M100.jpg
I don't know, the dowel looks like it is metal versus the thing I found which is black plastic material.
900-012-061-00-M100
DRACO A5OG 07-04-2016 01:54 PM
Thanks fellas!
Happy 4th you State Side Fellas :-)
