-   -   cross post- 964 rod length question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/920628-cross-post-964-rod-length-question.html)
rkeele 07-04-2016 09:24 PM
I have run into both Carrillo and Pauter rods that are about 2mm longer for 964 does anyone know why these are made for 964? thanks Bob
prschmn 07-05-2016 05:37 AM
Long rods
They are used with pistons with a reduced compression height-less rod angle
means higher RPM capability-and makes better power due to increased dwell time.
rkeele 07-05-2016 10:35 AM
Interesting Mark , so not recommended for use with Factory 3.8 rsr pistons? even if they are the 11.3 ones? wouldn't you need to shim the cyl. base also? thanks Bob
prschmn 07-05-2016 02:09 PM
No. RSR pistons are built for a specific rod.
