-   -   901 trans on a 7R case possible? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/921499-901-trans-7r-case-possible.html)
Mark Henry 07-18-2016 07:58 PM
Originally Posted by Walt Fricke (Post 9203063)
I believe that the air cooled VW, the 356, and all the air cooled Porsche 911s use the same engine to transmission bolt pattern. So they bolt up easily enough. The tricky parts are the different clutch and pressure plate styles and sizes, and I think being sure you have the clutch disk which matches the mainshaft splines (not actually tricky, if you know what you need).
The 901 is the same spline as all aircooled VW's, a beetle disc will fit...not that you would use one.
The picture I posted above is an adaptor I made out of a VW flywheel, a CSP performance VW bus 228mm pressure plate and a Sachs 228mm disc. It all bolts to 3.0/6 engine and a 901 (914) transmission.
Note that it would fit any 911 flat 220mm flywheel.
The later 240mm flywheel won't fit a 901 case
BTW When I built the transmission I changed the gearing to A, F, O, X, HA (flipped).
