-   -   2.7 Ignition distributor in 77 3.0 turbo? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/924944-2-7-ignition-distributor-77-3-0-turbo.html)
JohnOllen 08-10-2016 05:10 AM
I have a 77 3l turbo, less one ignition distributor. Have not yet found a 237301001 or 237301002 to install. Some have suggested I just run a standard 2.7l dizzie but Am concerned the different advance curve i
Will cause problems or at least poor performance. Anyone ever tried this? Thanks. http://forums.pelicanparts.com/uploa...1470830914.jpg
Steve@Rennsport 08-10-2016 11:13 AM
You can use a 2.7 distributor, however it MUST be re-curved and you will need a 3-pin CD unit since those have points.
