2.2 Crankshaft play
So my starter ate my ring gear, and I could not imagine why, until I was removing the flywheel bolts. The first one I touched the flywheel backed out about 1/2". Here's a wobbly video. Thrust bearing?
https://youtu.be/ipsfhOvMthI
Old 08-14-2016, 08:02 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Wow, that is allot of movement. I recently did work on my engine and noticed the in and out play but only 1MM or so.
But once I put the crank pulley back on, slop was gone. Is your pulley removed?
Also, is it the video or does the crank really appear cockeyed like that?
'85 Carrera Targa
PCA/POC
Old 08-14-2016, 08:50 AM
The pulley is still on, I'm waiting for cam tools to arrive, and then i will get to the bottom of this. I one handed the camera, while I turned with the other. I just can't believe the amount of movement
Old 08-14-2016, 09:42 AM
DRACO A5OG's Avatar
I had to resurface my crank pulley end and it was super annoying every time I turned it to insure evenness, kept jump in and out causing my dial to go crazy
Question, when you pulled the ring off, did you gradually remove it by removing each nut equally? I am sure you did but just incase you didn't install it te same way it could warp the starter ring gear.
'85 Carrera Targa
PCA/POC
Old 08-14-2016, 10:00 AM
215mm clutch, integral ring gear
Old 08-14-2016, 10:27 AM
The pulley shouldn't have any bearing on the thrust. All thrust should be handled by bearing #1 on crank. #8 is oil control, not thrust. That much play has to affect the distributor and timing inside on the crank.
Bruce
Old 08-14-2016, 01:16 PM
Can #1 wear that much without damaging the crank?
Old 08-14-2016, 01:22 PM
prschmn's Avatar
Even if the thrust faces were gone I'm not ure it would account for all that slop.
As was mentioned-is the face not square with the case?
That would be a busted crank.
And as Bruce said-the pulley shouldn't make any difference.
Either way you need to split the case but I'm afraid it's going to get ugly in there.
Sorry
Though I have a good crank here . Hopefully the case isnt damaged.
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
97 Van dieman F2000-gone but not forgotten
30 plus years of rebuilding services
Old 08-15-2016, 04:15 AM
I think the seal is cockeyed
Old 08-15-2016, 07:16 AM
Crank endplay and runout?
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 08-17-2016, 10:41 AM
