verifying main bearing specs for SC crank
On p. 204 of Wayne's book for SC crank:
bore (bearing dia): 60.020-60.059 mm journal dia: 59.971-59.990 mm main bearing clearance: 0.010-0.072 mm question: why isn't the bearing clearance the difference between the min-max bore and journal diameters i.e. 0.030-0.088 mm? |
| All times are GMT -8. The time now is 06:17 AM. |
