abit off center
Cracked rocker
I've seen plenty, burnt, pitted, broken but have never seen one crack in the nose area?
![]() Sent from my iPhone using Tapatalk
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Chain fence eating turbo
Had to have been porosity or contamination during casting
Member 911 Anonymous
Whoa, what a Night Mare.
Master CGarr, is this yours or a customers?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
It's not really a surprise as the material used is quite 'notch sensitive'.
The crack could initiate from any small surface defect such as a notch of a 'nick' on the edge of the pad. The shape of the crack would suggest that it's path has been dominated by the microstructure of the casting and the defects introduced due to how the part solidified and subsequently cooled. The question is when did the crack propagate - was it during manufacture, during operation or whilst being refurbished. |
I took it to Photoshop and lightened the shadows a little and cropped the top down.
Could you see this crack before refurbishing it and machining some metal off? It seems like 911 rocker arms have at least doubled in cost over the last 10 years. Are they plain old cast iron or something else? You do really nice work ![]()
abit off center
It's just a cast rocker. I'm sure it was there before I ground the pitting out of it. I have seen pockets open up in the surfaces before after grinding but never any cracking like this.
