964 Big End Bearing opinons pls
so......here is my latest stuff up.
In my journey to rebuild my motor and learn all about it, I was measuring my big end clearances...
The shells I have are the genuine porsche bearings.
I used plastigauge on one set of shells and as I was undoing the nuts, the rod rotated a bit.. (dry bearings and all that... )
I also used a bore gauge on the shells, with the rod off the crank...I figured, why the hell not, gone this far!
You can see all the resultant marks...
I cannot feel them with my fingers, but does the shiny stuff mean the coating is all gone?
Can these still be used?
Or should I buy a new set...
Mike.
here is another set out of the box, that I have not molested yet.. you can still see a little bit of a shiny patch on the edge...
Old 08-26-2016, 03:38 AM
prschmn's Avatar
use em
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
97 Van dieman F2000-gone but not forgotten
30 plus years of rebuilding services
Old 08-26-2016, 06:04 AM
D Troop 3/5 Air cav,162
afterburn 549's Avatar
Need more info,are you saying those have some time on them?
Do they all show the misalignment?
Old 08-26-2016, 06:07 AM
My bore gages have rounded tips on both sides. They can make a mark but not scratch as yours did. I'd look to see how deep the scratches are and then make my decision whether to replace or use. The lines where the crank turned don't look as deep as the scratches from your bore gage.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 08-26-2016, 06:30 AM
My bore gauge has rounded tips too.. and I was quite gentle with it.. the squiggly marks are not scratches.. they are just marks..
And no, these have not been used; they are fresh out of the Porsche Genuine packaging.
I think I will just use them.
Old 08-26-2016, 06:43 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
That silvery stuff is the anti-corrosion spray compound to protect the bearings in storage. The stuff scuffs off so easily, as you can see by the measuring marks on the other untouched (by you) bearing. It's basically immeasurable for our purposes.
Go ahead and use them, you'll be fine.
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 08-29-2016, 02:01 PM
thanks Kevin !
Old 08-29-2016, 02:04 PM
