Chain Tensioner O-ring
So I'm about to be at the step of the rebuild process where I have to install the chain tensioners, and I'm realizing I forgot to follow up on the small o-ring on the tensioners. The engine is a 1980 3.0, with updated tensioners installed within the last couple of years. I couldn't find the o-ring on this site anywhere but in the expensive tensioner rebuild kit. The old ones are still on the tensioners. Does anyone know where I can find this o-ring other than in the tensioner rebuild kit, or can it be safely reused, considering it's not too old? Apologies if that's a silly question.
Old 08-29-2016, 11:43 PM
Puny Bird
Mark Henry's Avatar
Do you mean the through the cover O-ring for the hydraulic tensioner?
The O-ring won't show up in the catalog because the 1980 3.0 didn't come with them, it came with mechanical tensioners.
Part numbers are 999-701-690-40-M17 or 999-701-690-40-OEM
1985 Porsche 911 Carrera Coupe - Camshafts & Timing Chains - Page 3
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 08-30-2016, 05:01 AM
Yes!
That's the one! Thanks for your help.
Old 08-30-2016, 05:38 PM
