arbita1's Avatar
Oil Pressure Switch Fitting Torque
Anyone know the torque setting for the fitting beneath the oil pressure switch?
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-03-2016, 01:55 PM
You just want it snug. The aluminum seal ring will distort and cause an oil leak when running if you over tighten.
Bruce
Old 09-03-2016, 02:25 PM
arbita1's Avatar
Thanks. Actually found the torque setting in the Bentley manual.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-03-2016, 04:07 PM
Torque values.......
Matt,
What torque values did you use for oil pressure switch? Thanks.
Tony
Old 09-04-2016, 01:34 PM
arbita1's Avatar
Originally Posted by boyt911sc View Post
Matt,
Tony
26 ft lbs
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-04-2016, 01:53 PM
That could not be right.........
26 ft lbs
Matt/ Jim (edited),
No wonder some people are breaking their pressure switch during installation. The Bentley Manual on page 130-4 shows only 15 ft.lb. torque. While Wayne's book says 14.7 ft.lb. Do you remember how much you torqued the thru bolts in your engine? They needed about 26 ft.lb. and they are solid steel bolts (M10). The oil pressure switch has a hollow threaded section and with a very flimsy connection to the switch body. Thanks.
Tony
Old 09-04-2016, 02:46 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 15 ft lbs just did mine.
'85 Carrera Targa
PCA/POC
Old 09-04-2016, 03:00 PM
arbita1's Avatar
Guys. I'm not talking about the switch itself. I'm referring to the fitting below the switch.
Matt.
83 911SC
85.5 944 NA - Sold
Old 09-05-2016, 04:59 AM
DRACO A5OG's Avatar
oops, my bad, need to open my old eyes and read
'85 Carrera Targa
PCA/POC
Old 09-05-2016, 06:44 AM
Fitting connection for the pressure switch........
Jim,
I misread it too. I have a better excuse because I am atleast three (3) decades older than you (Jim). The torque value for the pressure switch adapter is 26 ft.lb.
Matt,
Do you have a Bentley SC manual? Look at page 130-4 and you will find the different torque values for most of the fasteners for the crankcase.
Tony
Old 09-05-2016, 08:06 AM
