-   -   Front engine mount bar stud replacement! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/927999-front-engine-mount-bar-stud-replacement.html)
wprater 09-05-2016 08:09 PM
My case had the top left stud hole filled with JB Weld. This is where the support bar stud should be. I chiseled away the JB Weld and have been trying to drill it out, so I can re-tap the hole.
Not having much success, and it looks like this solid aluminum (like a case plug) vs JB Weld.
What options do I have at this point? Do I keep drilling and hope I get to the threads? I was planning to just chisel out the front part and then clean/re-tap the M12 hole.
Getting a bit nervous now and wanted to get some thoughts from the seasoned rebuilders out there!
Thanks!
https://www.dropbox.com/s/avnk7qf3au...peg?dl=0&raw=1
boosted79 09-06-2016 04:20 AM
So the JB Weld is gone and you are into just metal now? If so I would try a spiral EZ out along with a little heat on the case.
wprater 09-06-2016 08:05 AM
Its actually Loctite 9340 Hysol, but same general compound as JB Weld?
But you're correct, it looks as if the epoxy is gone, but why is there solid metal underneath it? Broken stud?
I'll look for better extraction tools like the spiral EZ out. thanks!
boyt911sc 09-06-2016 08:47 AM
Broken piece left behind..........
Start using the correct size drill bit for the stud extractor. Take your time and make sure the drill bit is straight and centered to the broken stud. Use a small pilot hole and enlarge as needed. Be very careful not to break a drill bit in the process and leave it stuck.
Tony
wprater 09-06-2016 08:50 AM
Good points.. thanks.
Anyone know how long this stud is here?
boyt911sc 09-06-2016 09:25 AM
If my memory serves me right, the threaded piece for this stud is about a little bit over 1". You don't need to drill through the stud. Depending on the type of stud extractor you have, 1/2" deep might be good enough to be able to get the stud out. Applying some heat will help loosen it too. Keep us posted.
Tony
tharbert 09-06-2016 09:36 AM
May want to try a left handed drill bit too.
wprater 09-06-2016 09:51 AM
Will keep you posted! Going to try and get some tools today before I out for a week.
You think it's wise to remove/replace the other studs for the mount bar while Im in the mood?
gtc 09-06-2016 10:19 AM
If it ain't broke...
boosted79 09-06-2016 11:26 AM
For sure. Why would you want to try to eff something up that isn't? Been there, done that.
wprater 09-06-2016 04:54 PM
I hear you! Not much luck so far. The extractor they sold me is not working very well, and these pilot holes Im drilling are starting to tunnel and Im worried they will become crooked.
Here is a new shot of my progress... not looking very good :(
https://www.dropbox.com/s/ad95tnwjcd...peg?dl=0&raw=1
https://www.dropbox.com/s/mbl68hs7we...peg?dl=0&raw=1
Walt Fricke 09-07-2016 12:24 AM
That looks like a good extractor.
This is a very odd situation. Those studs don't have a habit of just breaking off. And why in heaven's name would anyone, after one did, fill in the surface with epoxy?
If you can get the broken part out, you can use a Helicoil or other insert (requires drilling an oversized hole and using the tap specified for the insert)if you have damaged the threads in the process.
But while that works just fine on the transmission to chassis bolt hole when you have buggered up and cross threaded the threads (because you have the hole to pilot your drill), it looks like you have drilled your hole off center? If you end up with an insert off center, you are going to have to alter the engine mount so it will line up. And this bolt one of the long ones which goes through a tube in the mount. Be quite a project to move that tube.
But maybe you are centered? If so, try using a thicker drill? And keep going until you can see threads start to emerge. And if you still can't pick out the remains, or have damaged the threads, you have the insert option.
On the brighter side, I just measured a case, and it is at least 3.5" thick, so you won't be drilling into anything you shouldn't.
tharbert 09-07-2016 05:00 AM
Originally Posted by Walt Fricke (Post 9271124)
...On the brighter side, I just measured a case, and it is at least 3.5" thick, so you won't be drilling into anything you shouldn't.
That right there is golden info!
boosted79 09-07-2016 05:03 AM
If you can't remove it with the extractor then bolt the engine hanger on with the good studs and use that as a pilot to drill it out, you might have to have a pilot bushing made. I've had better luck with the spiral ez-outs. As you turn them CCW they bite deeper due to the left-handed flutes.
boyt911sc 09-07-2016 11:22 AM
Get the right tool.......
Use the right tool for the job. The one you have won't work like an EZ out left hand spiral as suggested by Boosted and you probably ruined the hole already. Or a left hand drill bit as earlier recommended. Google for 'screw extractor'. There are several models or types you could choose from that will do the job.
Tony
wprater 09-07-2016 11:32 AM
Good idea. Off to Boston.. back on Monday and then I'll try a new extractor. I suggested the spiral, but the harsware store guy said he's had better luck with straight edge. Should have just gone with my gut and what you guys suggested (silly novice, me.)
Im confident I'll get this fixed.. lots of sweat and swearing later.
Thanks!
wprater 09-07-2016 11:39 AM
It should be mostly center. The edges are chamfered slightly, which makes it look off-center. I'll be double checking and try to trim the edges and make another pilot if not.
I also like the idea of using the housing with a pilot bearing to be certain I can drill it out nice and straight. Perhaps even a side mounted drill press?
I think it may event be possible to retread to an M12 and fit the stud thorough the housing carrier as well..
Will be doing more due diligence on Tuesday after I return..
Thanks for all the help and support guys, will be keeping you updated.
Cheers!
cgarr 09-07-2016 12:13 PM
I would just drill out all the steel, if there is an easyout broken off in then get it with a carbide burr, clean it all out, weld it up and re-drill and tap the hole.
Walt Fricke 09-12-2016 09:26 PM
Craig - not everyone has a TIG in his garage. I think a Helicoil or Case Saver or the like would do fine. I've got some of those in the case to hold the bolts or studs joining the engine and transmission, and they do the job fine, so should do so here. Of course, those were not the result of a stud breaking off.
In thinking about a pilot to get drills straight, what about the motor mount itself? The other three studs should hold it just right, and it is a longish tube.
wprater 09-14-2016 02:45 PM
back at it with a new spiral extractor. its being very stubborn, so its hard to even rotate the thing. possibly because the pilot is slightly off center, its really hard to tell.
getting a welder in the shop to fill in the block and start over might be my best option at this point. Im not sure this damn stud is going to budge.. will report back end of day if I have good news to share!
Mark Henry 09-21-2016 05:08 AM
I had almost the exact same issue with one of my tranny mounting stud holes which had a very sketchy helicoil repair and a broken stud in the bottom.
I just drilled it out, I don't mess with easy outs.
I have a bunch of 10mm VW case savers that have an odd coarse standard outer thread at 1/2"-13.
Most well stocked aircooled VW shops would have this case saver..
Note the homemade insert driver, also I didn't have a tap, so I got one from China, $10 delivered to my door, but at the time I wasn't in a rush.
I think this is a good solution and I'm confident hanging my build from it.
http://www.914world.com/bbs2/uploads...1394543952.jpg
http://www.914world.com/bbs2/uploads...1394543975.jpg
http://www.914world.com/bbs2/uploads...1394543997.jpg
wprater 10-24-2016 02:38 PM
Was not able to get to the stud again with wedding trips and what not. I did manage to do a nice run through he N. Cascade Loop this last weekend! I was always planning to close out the Summer on that drive with my 78.. but here we are.
Im gong to drill it out and use a time-sert. Anyone have an idea of how long the insert should be 10x.15 x 30mm or 40mm in length? I'm not sure the length of the original stud, but there is enough room for a 40mm insert. Any negatives in that route?
I will use the carrier itself as a guide, if I can get a bit long enough for it. Im obviously a bit nervous to have this start to get off-center. :|
CobraR1339 10-27-2016 11:01 PM
I would just take it to a good machine shop. They have a few different ways to handle the problem. You have some very reputable P car shops in your neck of the woods. Hand tools will no longer get it straight IMO, well without a great deal of luck.
I have spent hours on crud like this over the years, only to end in more frustration, spending more it tools that a sano repair would have cost from a pro.
Kinda sux you are finding the issue after the heads are on, send them a pic and ask if they can handle if you don't pull it all apart. The motor is not all that heavy and may still be able to be set up on a lathe table, shimmed for square , etc.
wprater 03-28-2017 02:28 PM
sorry for the late response, but I took it to a shop and got it replaced. :)
http://forums.pelicanparts.com/uploa...1490736482.jpg
JFairman 03-28-2017 05:50 PM
Looks like a Time Sert installed with blue loctite. If it's installed well now it's stronger than it was originally.
If you ever break off a drill bit or easy out in something expensive you can drill them out with a Cobalt drill bit. Snap On has them and hopefully they are available from other places too. They are amazing drill bits and will drill through any metal I know of.
