petercoetzee's Avatar
Location: Cape Town, South Africa (if i buy any parts I ship to US address)
Long period between build and first start - correct maintenance?
Hi guys,
Its been about a year and a half since my motor was done, as projects go I just haven't got around to cranking and I'm worried about moisture build up.
Every second month or so I crank the motor, just until I see the pressure needle move. All fluids are in and in the transmission. I warm the garage considerably before as additional precaution. I know its probably safer to pull the plugs and turn over by hand, but alternatively is cranking ok?
Old 08-27-2017, 11:49 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
youll probably get varying responses, but I think what you're doing is probably ok. make sure the fuel system isnt hooked up. If you turn it by hand, you'll never get oil pressure.
Old 08-29-2017, 11:04 AM
