Stock steel head studs on a 930
Who has used stock Porsche steel head studs on a 930 engine? I am considering pulling the heads and this seems a safer replacement than pricy aftermarket or Dilvar. I don't plan anything above stock boost levels for this.
Old 09-17-2016, 10:15 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Early 930 engines came with Dilivar studs top and bottom.
They should be replaced.
If you're going through the trouble of removing all the studs, why not use the best.
Supertec head stud kits are well worth the cost in quality, ease of engine assembly, reliability and cylinder to head stability.
The best selling studs on Pelican Parts.
1979 Porsche 930 Turbo Coupe - Cylinder Head & Valvetrain - Page 6
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-17-2016, 11:03 AM
