-   -   911 sc no compression in 3 cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/929381-911-sc-no-compression-3-cylinders.html)
bevanclark1 09-18-2016 11:51 AM
Have a project car underway ,engine with no compression in 3 cylinders on one side . What the most likely cause?
Steve@Rennsport 09-18-2016 12:23 PM
Do a leakdown test to find the source of the problem.
Lapkritis 09-18-2016 12:54 PM
Most likely? Jumped or broken timing chain on that side.
Flat6pac 09-18-2016 01:21 PM
Yes, the cam setting isn't right...or its jumped time
Bruce
silverc4s 09-18-2016 02:30 PM
And/or you have 3 bent valves as a result...:o
