-   -   differences in the blocks between 3.0 and 3.2 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/929933-differences-blocks-between-3-0-3-2-a.html)
Mick_D 09-23-2016 09:58 AM
What are the differences in the engine case between 3.0 motor and a 3.2 motor? Are the cases the same ?
Flat6pac 09-23-2016 11:18 AM
The cases are the same except the Carrera hasn't got an oil sump but it does have a boss on top for a Z1 sensor that today is worthless and it has 2 bolt hole bosses for the flywheel sensors that may well be able to be duplicated.
Bruce
Mick_D 09-23-2016 11:47 AM
OK, so I could technically use a 3.0 (SC) block and build it out to a 3.4?
Flat6pac 09-23-2016 02:32 PM
You need the crank and rods from a Carrera and the cylinders from a Carrera opened to 98 for the sealing taper to the heads.
Bruce
Mick_D 09-23-2016 03:11 PM
When you say Carrera, do you mean the 3.2 motor?
Flat6pac 09-23-2016 04:03 PM
Yes. The crank, rods and 23 mm wrist pin is the 3.2
Bruce
