VW 612 RS's Avatar
Piston ring problems
I have a brand new Mahle P/C set.
During the preassembly of the engine for checking valve to piston clearense I discovered some bad marks at the barrels.
After some investigation we found out the middle ring made those black stripes.
The edge of the ring have some roughness who you can feel with the fingers.
Have been in touch with Mahle and they don't of this problem.
The have never heard of those problems before.
All the six rings are the same.
The ring gap is 0,35mm.
Has anyone had such problems?
Old 10-01-2016, 07:34 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Macro picture of the rings? Just curious what they look like where the roughness is.
Old 10-01-2016, 08:33 AM
VW 612 RS's Avatar
I will try to take some macro pictures
Old 10-01-2016, 09:06 AM
Did you file the ring gaps? I recently found that the 2nd ring on a set of JE rings developed a noticeable burr when I used my piston ring grinder and I had to dress each one with a small file to remove the sharp edges. The 2nd ring was much worse than the top rings.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 10-01-2016, 05:13 PM
VW 612 RS's Avatar
No, I havenīt file the gap.
I will order a new set first to compare.
Have some thoughts about to try to use 1200 sandpaper
Old 10-02-2016, 07:20 AM
Puny Bird
Mark Henry's Avatar
Are these nikasil /6 cylinders?
I seen these marks when new, but nikasil is hard as hell so as long as it's not deep (as in you can't feel them) it's OK and normal.
Nikasil is way harder than the rings.
Of course check to be sure.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 10-03-2016, 09:05 AM
theiceman's Avatar
ok il ask the question as i just don't know ..
when they sold you the p/c set did they provide the rings also or are they from a different provider. ? were they shipped to you assembled or did you do all that yourself ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-03-2016, 10:09 AM
VW 612 RS's Avatar
Those marks came after the pre assembly.
Old 10-03-2016, 02:38 PM
VW 612 RS's Avatar
I guess the ring comes from another provider.
The rings came beside the piston in a plastic bag.
I did the ring assembly.
But I have bought Mahle P/C earlier where the ring where assembled.
I have a dialog with Mahle to figure out what we do next.
Old 10-03-2016, 02:44 PM
Just fyi my Mahle P&C came with rings assembled on pistons allready.....
Old 10-04-2016, 05:49 AM
Puny Bird
Mark Henry's Avatar
My Mahle's were pistons only and they came with the rings installed.
Old 10-04-2016, 07:24 AM
