-   -   964 cam tower or 993 cam tower (http://forums.pelicanparts.com/911-engine-rebuilding-forum/931890-964-cam-tower-993-cam-tower.html)
txhokie4life 10-10-2016 08:03 PM
Race engine
964 heads (worked)
964 rockers
I had a pair of 993 cam towers, but the cam shafts damaged the journals on the housing.
I mistakenly acquired a set of 964 cam towers. Now I'm trying to decide if
I part ways with the 964 cam towers and find a set of 993 cam towers?
Mike
prschmn 10-11-2016 05:54 AM
Unless you're using hydraulic rockers why not just use the 964 ones?
txhokie4life 10-11-2016 07:04 AM
Well in some ways -- that's what I'm asking.
The 993 towers look like they would have the opportunity to leak less as the rockers are encapsulated.
Does the 993 have a better rocker oiling scenario?
Mike
prschmn 10-12-2016 03:57 AM
Rocker oiling yes-but cam lobe oiling-uhuh-you'd need to add holes in the spray bar
