-   -   Anyone have distributor curve info for a carbed 2.7? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/932446-anyone-have-distributor-curve-info-carbed-2-7-a.html)
tornik550 10-15-2016 05:32 PM
Does anyone have any good distributor curve data to use for my carbed 2.7 with e cams? I ordered a programmable distributor and was trying to get curve info for when it arrives.
SoyRacer 10-15-2016 09:35 PM
What carbs?
What manifolds/exhaust?
etc etc
Steve@Rennsport 10-16-2016 01:10 AM
Most importantly, what octane fuel will you use?
tornik550 10-16-2016 04:44 AM
I will be using 92/93 octane gas.
Here is my setup. My car is used for spirited street driving. I was interested in lowere ebd torque and power than high rpm power.
Carbs- Weber 40 ida 3c- 34mm vents
Manifolds- not sure however they were CNC matched from the Webers to my heads
Heads- intake port 35mm, exhaust port 32mm (cleaned up on flow bench). Valves 46/40
Exhaust- 1 1/2" headers.
Stock 2.7 crank, rods, cylinders, 9.5:1 pistons
Camshaft- E cams
tornik550 10-17-2016 11:47 AM
I received my new distributor today. Very quick shipping. Appears great and very solid.
Any recommendations for a starting point for the curve would be greatly appreciated. http://forums.pelicanparts.com/uploa...1476730063.jpg
E Sully 10-17-2016 05:21 PM
Porsche stock curve for 2.7- 2.4 T, E, and S. The only thing different was the rev limiter.
http://forums.pelicanparts.com/uploa...1476749940.jpg
