-   -   How to identify cams? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/933945-how-identify-cams.html)
mb911 10-29-2016 02:48 PM
I have a 2.4 former mfi engine I have had for years.. I am taking it down for heads and probably p&'s.. How can I tell what cams are in there and if they are regrinds?
Flat6pac 10-29-2016 03:48 PM
Usually, there will be a stamping on the bearing end if they've been worked and possible a stamping on the nose.
Factory cams have a casting number on the side which can be looked up in reference books.
Bruce
mb911 10-29-2016 03:58 PM
Thanks I will check .. The engine has defiantly been apart before and has plugs in the mfi heads already so I would think they would have used different cams then mfi for carbs.. I guess we will see.
tom1394racing 10-29-2016 04:55 PM
Check out the cross reference table in this thread
http://forums.pelicanparts.com/911-engine-rebuilding-forum/537394-looking-2-7rs-cam-body-evaluation.html
