#147 of 2096
Help me id this flywheel.
Hi,
I need to id this flywheel (the left one) (I have two of thems)
It is 930 in size, later bolt flange pattern but small spigot like maybe 2.4-2.7
Any idea?
RSR?
It's the one on the left of the picture.
Thanks.
#147 of 2096
Old 11-27-2016, 07:18 AM
Left Hand Photo - Early 3.0 SC with 9 Bolt fitting and press fit Pilot Bearing -
I believe Part No. 930.102.204.00
Right Hand Photo - Late SC with 9 Bolt fitting and bolt -on style Pilot Bearing -
I believe Part No. 930.102.215.00
I also believe that all RSR's both 2.8 and 3.0 litre had 6-Bolt Crank/Flywheels
We make our own 'RSR' Style Versions of both of these 9 Bolt Styles
We also make the original 6 Bolt Style
Old 11-27-2016, 07:47 AM
#147 of 2096
Thanks Chris.
It uses 930 pressure plate. It is the one you mentioned?
Thanks.
#147 of 2096
Old 11-27-2016, 10:53 AM
Both of these flywheels use a 225mm diameter clucth
Old 11-27-2016, 10:56 AM
#147 of 2096
Nope,
That is the curious thing.
#147 of 2096
Old 11-27-2016, 11:00 AM
#147 of 2096
Let me attach another picture
#147 of 2096
#147 of 2096
#147 of 2096
Old 11-27-2016, 11:02 AM
#147 of 2096
It is from a 930
#147 of 2096
#147 of 2096
#147 of 2096
Old 11-27-2016, 11:06 AM
The turbo flywheels have a thinner raised edge than the SC flywheel.
Bruce
Old 11-27-2016, 11:57 AM
