Help me id this flywheel.
Hi,
I need to id this flywheel (the left one) (I have two of thems) It is 930 in size, later bolt flange pattern but small spigot like maybe 2.4-2.7 Any idea? RSR? It's the one on the left of the picture. Thanks. http://forums.pelicanparts.com/uploa...1480259879.jpg |
Left Hand Photo - Early 3.0 SC with 9 Bolt fitting and press fit Pilot Bearing -
I believe Part No. 930.102.204.00 Right Hand Photo - Late SC with 9 Bolt fitting and bolt -on style Pilot Bearing - I believe Part No. 930.102.215.00 I also believe that all RSR's both 2.8 and 3.0 litre had 6-Bolt Crank/Flywheels We make our own 'RSR' Style Versions of both of these 9 Bolt Styles http://i197.photobucket.com/albums/a...ps1bcylaiz.jpg We also make the original 6 Bolt Style http://i197.photobucket.com/albums/a...psz7vdordt.jpg |
Thanks Chris.
It uses 930 pressure plate. It is the one you mentioned? Thanks. |
Both of these flywheels use a 225mm diameter clucth
Nope,
That is the curious thing. |
Let me attach another picture
It is from a 930
The turbo flywheels have a thinner raised edge than the SC flywheel.
Bruce |
| All times are GMT -8. The time now is 11:03 AM. |
