MFI Filter Console
http://forums.pelicanparts.com/uploa...1095690225.jpg "
(C) 1972 Dr. Ing. h.c. F. Porsche A.G. We are trying to completely refurbish and MFI system and looking at the Filter Console ITEM 6 is missing from the unit that we have installed on the car. It is shown as a 'Shim' and is NLA. Does anyone know its function and the correct thickness? |
Chris, just a standard copper washer to seal the fuel. Just pulled one and it measures 0.9mm crushed. So a 1.0mm copper washer ill do. Hope this helps.
Rusty |
Item 12 is the 'seal' which is indeed a Copper Washer.
The 'shim' appears to be a separate part which is why I am confused. |
Chris, I busted checked PET and see the shim, just checked 2 other units and neither of those have the shim. One unit is on my 70 S and worked as it should. Car is actually a 71E, just running a S engine. Didn't want to mislead.
I have checked 4 of them - none have the D****d shim either ???
| All times are GMT -8. The time now is 07:32 AM. |
