Mega squirt. 2.4 engine build?
I am in the process of building a 2.4 with mild ported heads, s pistons, soles cams and currently have webers. I am considering doing mega squirt again and making a sheet metal intake similar to the 3.2 or vario ram 3.6.. And have a few questions.
1st would this be an acceptable combo?
2nd would it be necessary when building the intake to have. Rubber connection like the 3.2 or could it be 1 piece. I am assuming 2 pcs required because of the engine growing?
3rd my Weber cores are very nice I am just not a huge fan of carbs and fuel injection is so nice and I have had good success with mega squirt on past builds.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-10-2016, 08:38 AM
911 Turbo's used a one piece pancake intake manifold that tied the intakes together. It is a cast magnesium unit. So a one piece aluminum intake should not require an expansion provision. I think the reason the 3.2 Carrera intake is in two pieces is for ease of casting.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 12-11-2016, 08:59 AM
Good point
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-11-2016, 11:51 AM
al lkosmal's Avatar
plenum
Ben,
Are you planning on ITBs with a shared plenum? If so, you may want to touch base with Marc Zurlinden. He has developed a very cool intake.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 12-11-2016, 01:11 PM
Was thinking single throttle body like a 3.2 intake.
Ben
89 944,85.5 944
914-6werkshop.com
Old 12-14-2016, 08:44 AM
JmuRiz's Avatar
Very cool idea, seeing as prices of 3.2 intakes seem to be quite high these days.
I want to do EFI in the future (when I can afford it) and want to get a baseline with carbs first so it's easier to chase where the issue is, Fuel or Spark, when I go EFI.
If it's like the other stuff you've made, you'll have people wanting you to make copies to sell.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 12-14-2016, 11:01 AM
Puny Bird
Mark Henry's Avatar
Ben this is link on a how to for a subi six plenum, a 911 would of course have to be a bit different, but it's likely a good starting point.
SDS EM-4: Aircraft
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 12-14-2016, 01:58 PM
