-   -   Line boring crankcase (http://forums.pelicanparts.com/911-engine-rebuilding-forum/937892-line-boring-crankcase.html)
roialex 12-05-2016 10:55 AM
Originally Posted by tharbert (Post 9384148)
Yes. The case warps as it's unbolted. There is a recent thread where someone tried to reassemble a mag case without it being machined. The crank seized as soon as he tightened the thru-bolts.
it's me ahahaa
cmcfaul 12-05-2016 11:55 AM
Olies is a good call. Probably want the oil bypass mod and Case Savers instaled while you are at it.
Chris
prschmn 12-05-2016 03:20 PM
Before anything is done the bore diameter should be measured. Often you'll find that it has actually become smaller and if that's the case it can be line honed-not bored into spec without having to surface the case halves. You do need to put an alignment plug in the intermediate shaft bore
to get a good result though. Most of the rigidity is in the mainline and a few out on the perimeter
isn't a big deal. I do usually install locating sleeves towards the center as a precaution.
faapgar 12-06-2016 12:02 AM
case
Good advice from Mark.If the straight edge is flat on the case halves sometimes all you need is a clean up line hone.Fred
DaveA 12-06-2016 08:46 AM
Send the case to Olies. Excellent work and fair price. End of story. R/Dave
