Euro C/R JE Piston question
I am in need of new pistons for my '88 3.2 after some bad piston slap. The plan is to re-nikasil the cylinders and have a set of JE pistons to match . I am currently running a euro premuffler and sport exhasut with 964 cams.
My wrench mentioned having custom JE pistons done at 10:3 C/R. I do not want to go down the twin plug route and after seeing many posts on Mahle's vs, Nikkis, vs Max Mortiz pistons I cant seem to find anyone with stock 95 Mahle cyliinders running 10:3 JE pistons. Is a reason for that? I also plan on having Steve Wong make a chip for he set up as I can get 93 octane and he recommended sticking with stock C/R because of the the dome design of the JE pistons. Any input on a 10:3 C/R with JE and Mahle's? Should I just do a 98 piston at 9:5? thanks |
I'd stick with the 9.5s JEs. They have a "flat" dome that will just shroud the chamber too much
at higher comp. ratios. Moritz used an angled dome to try to alleviate this. |
Thanks Mark, any benefit of going to 9"8 or 10? or dont bother?
Before anything I'd love to know how you got piston slap on a 3.2-not normal unless
it's got a zillion miles. Are these K E jugs? |
If getting them replated and purchasing new JE pistons, consider boring to 98mm for a 3.4.
98mm
JE will build you a 98mm Max Moritz 9.8 that will work just fine.Add your chip from Mr.Wong & do not look back.Add just an aluminum flywheel and enjoy.Fred
| All times are GMT -8. The time now is 05:43 PM. |
