Senior Member
john_colasante's Avatar
Sealing #8 nose bearing to case.
Can you elaborate on sealing the #8 nose bearing? In the preview edition you do not discuss using sealant between this bearing and the case. You only say use Curil between the #8 bearing and the crankshaft pulley seal.
The factory manual does not specify using sealant between the #8 bearing and the case, it only mentions the O-ring. In the main forum there are lots of opinions. This seems to be a major potential leak area.
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 01-11-2003, 01:25 PM
Author of "101 Projects"
Wayne 962's Avatar
There's an o-ring that fits around the number eight bearing. If you're nervous about it - a small bit of the Curil-T can't hurt, but it shouldn't be necessary. I think that the number eight bearing almost always leak from the pulley seal - not the o-ring. I did forget to mention the o-ring in the preview edition, Chris pointed that out to me, and it is now in the production version...
-Wayne
-Wayne
Old 01-11-2003, 01:27 PM
Super Moderator
cstreit's Avatar
Well I took the high road and installed it without sealant... Lubricated it with oil so it would expand properly when the case was torqued. We'll see!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-11-2003, 08:43 PM
