case sealants
I used loctite 518 twice until now, first time with good results, latest time with leaks. I absolutely hate this, thus the engine will come apart again (which basically is the most interesting thing for me in this hobby). I am intending on using Dirko HT as per John Walkers advice. What is the best way in applying this?
I've never heard of the 518 stuff - you need to use the 573 or 574 (factory recommended), and make sure that the case seams are 1000% clean...
Of course, everyone has their own personal preferences... -Wayne |
Peter,
I asked JW this very question a while back. He says he likes to "spread it with his finger". Mind you, John has a well calibrated finger; more accurate than the rest of us D-I-Y'ers. |
I used the 518 (http://www.loctite.com/catalog/product.html?ProductLine=518+++++++++++++++++) stuff because I heard it suceeded 574. I basically think I applied it to thin because I was afraid of it squeezing into the crankcase and cause all kind of havoc in the oil circuit.
From what I learned about 574 one advantage of 518 is that you have longer to assemble the case before it hardening. Anyway I trust in John Walker and also from looking at the elring (producer of Dirko and Curil) specsheets it seems to be up to the job. |
You have about 45 minutes to assemble. The 574 sealant disolves in oil - it does not gum up the inside of the case - it only bonds in metal to metal contact. You dont' need to be concerned about squeeze out on the inside of the case.
I would go with what works, and what 1000s of others use - the 574. It has not been superceded, and is available today on this website... -Wayne |
I am ashamed to admit I got the loctite 518 knowledge of the automotion catalogue: "Red Loctite #518. After years of development of case sealants, Loctite has created a Red Loctite which not only is far superior over the Orange version, but has a far greater adhesion rate for high temperature applications. Used by most shops not only for rebuilding high performance cases, but also for gaskets too. Expensive, but isnt your new engine worth it?"
I thought so........ When I take it apart I will have a look what exactly caused the leaks. I am fairly sure it is human (mine) error. I am also sure that several sealants will perform when applied in the right way. When you look at the specs of Curil, Dirko, Hylomar or Loctite they all claims to do the same and have their advocates. I was a bit "scared" of 574 because of the stories about it curing to soon and spoiling tolerances of the bearings. |
Spoiling the tolerances of internal components is complete hogwash and poppy-cock. It does cure quickly - you have about 45 minutes to work, but that's about standard working time for most sealants.
I haven't read that in the Automotion catalog, and I've never talked to anyone who has used that. Take it from me (I know), the people creating the catalog don't always know too much about the actual cars... :) -Wayne |
what about Dow730?
It is expensive, about $70 per tube, but I have never had a leak since using it. When I refresh my engine (about every other year) I go to my friends shop and borrow the tube. seal my engine and return the tube... The first time I rebuilt a 911 i used permatex pliobond....go figure it works and is cheap.. |
The 730 stuff is like super-duper adhesive - very good, but I don't like to use it everywhere...
-Wayne |
Wayne, big faux pax You actually know something about these cars. |
Sometimes my employees (who would be let's say 914 experts), don't know as much about the 944 line, etc. That is what I meant...
-Wayne |
I don't know about you guys but I used Loctite 518 on my recent rebuild. After 3 weeks NO LEEKS. I just squeezed it on one side of the case and spread it with my finger. The other half of the case I used a primer.Tried Yamabond twice but seems to set up to quickly{once it leaked once it didn't}.
Kevin 72 911T/E |
I know a shop that used 518 for 911 motors (Foreign Intrigue). I use 574 for the case and 518 for the cam towers.
The Automotion catalog said "Expensive, but isn't your new engine worth it?" Of course they failed to mention it was only expensive if you bought it from Automotion ($18+shipping). It was only $12 at the local NAPA store. -Chris |
I have a tube of 3-bond 1104 here leftover from a snowmobile engine rebuild. anybody use this?
I have been using Three Bond and never had a leaking case. Costs about $10 a tube.
-Chris |
As a professional chemist (PhD Caltech 1984), I read that Loctite 574 is a polymeric resin which cures in the absence of oxygen as when the case halves are mated together squeezing out all traces of air. I don't know if the 45 min setting time was a time for the solvent to evaporate but the seal definitely cures and bond to the metal in the absence of air. I have no idea how the other stuff works.
I have used 3-Bond 1104 on m/c engines. Never had any problems with it in that application. I noticed it seems to be quite similar to Dirko.
I would recommend the Loctite 574 - Walt uses it and so does Tom Woodford...
-Wayne |
I actually just posed this question on the regular 911 board, (anyone use 3-bond?), apparently some here have. I have no doubt that any of these products that are designed as case sealers will work IF prep and application+ assembly is done correctly, what I wonder now is differences in set-up time, ie. how long do you have between application of sealer and cases mated?
I was considering Yamabond or Hondabond, (supposedly same stuff), big savings and for all I know it works as well or better than Loctite 574. Anyone use it and have some miles/time on a motor w/ no leaks? TIA. :cool: |
I switched to Yamabond about 5 years ago-after 25 years of trying every glue
out there-it does work well, but you must move quickly when assembling and surfaces must be perfectly clean and dry. |
Wayne, does Pelican sell any type of sealant at all? I must have spent an hour looking through every page of the on line catalog last night.
I'm still working on the expanded rebuild section. If you search for 574, it comes up in the search engine...
-Wayne |
The problem with using all of these aftermarket sealants, is that no one really knows if they stand the test of time, and if they produce a thin enough seal to seal the cases.
Don't forget that there is no gasket between the case halves, so the sealant must be extremely thin there, otherwise it will affect the tightening, twist, and bearings within the case! It is for this reason that the application process of the Loctite 574 is completely different than that of the Dow Corning 730 stuff. The Loctite should be spread evenly using an acid brush over all contact surfaces. The Dow 730 sealant needs only a very small, thin bead that is then compressed by the case. Laying on the 730 thick will produce too much thickness. The bottomline is that you can just arbitrarily choose a sealant and use it without knowing in detail it's intrinsic properties. It may spread to thick, it may not compress enough, it may break down when in contact with aluminum or magnesium, or even motor oil. The Dow Corning 730 and Loctite 574 materials have been proven to work over the years - I wouldn't want to experiment with the case halves on assembly. -Wayne |
Hello
573 was replaced by 574. Usually you use a little color roller to roll on a thin 574 layer on the surfaces. Ther are always big questions if you have to apply it abouve the complete surface or only on the case-edges especialy when you come to the bearing #1 section ( flywheelend ) with the shuffle pins you have the sealer between the bearing. Some people then use sealing also over the complete case ( say all the other mains ) to achive a even hight. The fine thing on 573/574 is that you can apply it very thin and it will not add to much thickness so it will not affect the bering galery. So you can aplay it on the critical spots as well. 573 and 574 love good storage and some shaking up, massaging before use. Stored wrong and to long it will sperate internal and work uneven on the surfaces later. 574 is also aviable packed in tubes from Würth. 518 is a more spreadable usage sealing but i think it will not outperform the 574 ( 518 does fills gaps better ) Grüsse |
573 is/was green and 574 is colored orange
Hi Roland. Not 100% correct, but close. The factory replaced 574 with 573 - both products are indeed still available from Loctite (according to their reps, and their website). The 573 is nearly identical to the 574 except it has a longer working time...
-Wayne |
Hello
AFIR 574 was used on the head to camhousing in 88 on and from 89on it was used on the case as well. If you check your workshopmanual you will find the new loctite 574 descriped and Porsche recomened to use up all the 573 stock asap. Here in germany 573 is still listet. 573 has a much longer "open time" and will need longer to bond trough. It also doesn´t fill gaps as 574. AFIK the 574 was needed to speed up production process. For professional use you can get the 57x series in retangular softbagcanisters with 2,5 L contens ;) 574 can be substitutet with 5208 http://www.rolf-richter.de/html/flachendichten.html http://www.loctite-europe.com/de/loctite_518.htm http://www.loctite-europe.com/de/loctite_573.htm http://www.loctite-europe.com/de/loctite_574.htm http://www.loctite-europe.com/de/PRODUCTS/5208.htm Grüsse |
| All times are GMT -8. The time now is 08:24 PM. |
