-   -   Help! Strange Deformation on Head??? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/938917-help-strange-deformation-head.html)
DRACO A5OG 12-11-2016 08:45 PM
Okay Master Re-builders,
I have a new one here, have any of you every encountered this type of damage and if so is it repairable?
#4
http://forums.pelicanparts.com/uploa...1481517613.JPG
I have a raised lip aka "fretting"
TIA,
Jim
prschmn 12-12-2016 04:42 AM
It's that ole loose nut thing again---head moves around with firing pressures
faapgar 12-12-2016 04:58 AM
leaky head
You need a 3.2 head gasket repair part.6 of these and they are .5mm thick.I think the part # is 930-104-381-01.I used to pay about $100.00 for 6.Only buy them from Porsche as there are copies but they are not the same with the coating on the gasket.Fred
DRACO A5OG 12-12-2016 09:49 AM
Oh thank you Brother Faapgar, noted. :D
