Case is together!
Well it took almost 10 hours to complete with 3-5 people at any given point. (Including an hour for lunch and probably 90 minutes for philisophical questions and debates) but my case is together!
I especially wanted to thank Souk and Ray911s (and their wives/significant others) for staying for almost 9 HOURS to assist, and lend encouragement. Thanks to Keith0. for helping install the crank too! I'm happy with how it turned out! Souk took a ton of pictures untill his battery ran out. We'll post them later. A few "fun moments". 1) We almost forgot the cam chains! 2) I overtoruqed the perimeter bolts by 7 lbs, oops.. But went back one-by-one and un-retorqued them properly. 3) We didn't open beer untill everything was triple checked. THere were a few more amusing moments, but I'm way to braindead after 9 hours in the garage to share them all now... THanks again guys, where else would on-line BBS, car guys, recent aquantences put 9 hours in to someone elses motor "just because." THANKS! :) |
The Loctite 574 usually cures in about 45 minutes - hope you guys didn't take 9 hours to bolt the case once you put the halves together!
:) -Wayne |
Wayne,
I'm not THAT slow... We had the initial 50% torque completed in about 20 minutes and the final torque completed in 30 minutes. I'm pretty confident that it sealed well. We got a good consistent ooze-out from tightening the bolts around all the seams with no gaps... |
Crank assembly
http://forums.pelicanparts.com/uploads/lr12a.jpg That's 10+ hours of cleaning that case. You COULD eat off it. http://forums.pelicanparts.com/uploads/lr13a.jpg Factory approved engine case sling. http://forums.pelicanparts.com/uploads/lr19a.jpg A very expensive Christmas tree http://forums.pelicanparts.com/uploads/lr20a.jpg Flywheel seal http://forums.pelicanparts.com/uploads/lr22a.jpg The crank is IN! (and those nifty rod holders too. http://forums.pelicanparts.com/uploads/lr26a.jpg Factory cam chain device... http://forums.pelicanparts.com/uploads/lr29a.jpg Yours truly. Mr. Goodcheer! Notice the red Duct-tape "flags" where I wanted to make sure we didn't forget to torque something... http://forums.pelicanparts.com/uploads/lr30a.jpg We did it... http://forums.pelicanparts.com/uploads/lr31a.jpg It's Guiness time! http://forums.pelicanparts.com/uploads/lr32a.jpg |
What kinda flywheel you got there HotRod? :D
Maybe you don't need to worry about that flywheel seal either. Looking at your picture, it looks to be at full depth? |
Hey kevin...
It's a modified stock flywheel actually... Just lightened "a bit" :) The seal was at full depth in the picture, but it pushed out a bit when we were sealing the case... :( |
Good job cleaning the case!
-Wayne |
Thanks Wayne. You were obviously very adamant about his in your book, so I cleaned it to the "white glove" point. Last thing I wanted was some stray material burning up a bearing or blocking a squirter.
I also used your rubber hose trick to help blow out the piston squirters, worked like a charm. |
| All times are GMT -8. The time now is 12:12 PM. |
