-   -   04 996tt piston ring gap question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/939367-04-996tt-piston-ring-gap-question.html)
t-tom 12-15-2016 01:04 PM
Does anyone know what to set the piston ring gaps at on a 04 966tt. The pistons have the ring stop pin/dowel on the second ring land
prschmn 12-19-2016 08:16 AM
Since those are water cooled cylinders I'd say use the usual standards for gap. I.E. 4.5-5.5
per inch of bore for top rings. Most important for second ring is that the gap is larger to prevent
pressure buildup between the first and second rings.
