Possible error in the engine rebuild book. D1 wear limit.
I was measuring my crank earlier this week with my mechanic and we think we found a little typo. See attached image. Shouldn't the D1 wear limit for the larger cranks on the 3.0 and up be 3mm larger than the earlier cranks? They are listed at 56.960 all across the chart.
http://forums.pelicanparts.com/uploa...1481909048.jpg |
Per PAG tech manual page 32: Visual Inspection Wear limit is 59.960.
So what was the measurements you two found? |
Looks like I have a first edition version of the book which has the error. The correction is listed on the official corrections page. I missed it because I was looking for corrections in the second edition, which I thought I had since I just bought it earlier this year. The correction was made in the second edition. I'm getting to the bottom of it with Wayne's help.
It measured 59.980, so right where it should be. |
Perfect, I am going thru the same process, splitting engine case today :eek:
Break a Leg Brother Jameel :D |
| All times are GMT -8. The time now is 03:16 PM. |
