-   -   Max Moritz/Deep Pockets S-Cams (http://forums.pelicanparts.com/911-engine-rebuilding-forum/93949-max-moritz-deep-pockets-s-cams.html)
Eric Shea 01-12-2003 09:47 AM
Has anyone ever cut deeper pockets in a set of Max Moritz pistons for use with S-Cams? I currently have three options for building my 3.0/3.2 MFI motor:
1. JE's for 3.0 with 9.5:1. Haven't heard great things about JE's but it's still debatable. (noisey/expansion rate etc...) $1k
2. Mahle Max Moritz 3.2's with 9.8:1. Just need to figure out if there's enough material there to cut deeper pockets for the S-Cams. Around $1k used?
3. Mahle 3.2 RSR Pistons. Compression ratio would be reduced enough by using with the SC heads to allow for streetable CR (I'd like 9.8:1). Don't have actual CR figures though. Has anyone ever done this? Thoughts on what the CR might be? $3k plus! ouch (talk about deep pockets).
Thanks for any input... the pistons are the great abyss I need to cross before moving forward on this engine. It seems as though everything is dependent on them.
Eric
cstreit 01-12-2003 11:33 AM
Mahle has some new distributors now, the one in Dallas offered a price several hundred dollars lower than Andial FWIW
Wayne 962 01-12-2003 11:55 PM
JE Pistons are fine - they are excellent quality...
-Wayne
emcon5 01-13-2003 09:37 AM
Wayne, can you get Mahle Max Moritz 98mm sets? If so, how much?
Thanks,
Tom
emcon5 01-15-2003 10:20 AM
I hate to bump my own post, but also don't want Wayne to miss this question.
Tom
