-   -   ARP head studs - which way to install (http://forums.pelicanparts.com/911-engine-rebuilding-forum/941433-arp-head-studs-way-install.html)
Lapkritis 01-13-2017 10:13 AM
ARP also uses standard thread nuts in many applications. If you tried to install backwards into a metric base with the imperial end, you'd figure this out quickly.
Sent from my SM-T580 using Tapatalk
DRACO A5OG 01-13-2017 01:11 PM
Thanks for the info but for this specific TOPIC, OP's and my ARP heads studs for our 911's are METRIC on both ends. I just verified it.
Lapkritis 01-13-2017 01:28 PM
Thanks for checking. I wasn't about to! ;)
