engine drop on 911SC Targa
I'm sorry to create yet another thread on a topic that has been covered so much but this will be my first engine drop and....
I have to drop the engine in my '82 911 SC Targa and my question is what is the best way to get the rear of the car high enough to drop the engine: With a Targa is it better to jack it up from the side factory jack points (a little at a time) or from the rear (crankcase)? Despite the warnings many of you successfully jack the car up from the crankcase and I found one thread where the owner created a nice wood adapter: ![]() ![]() Here is another Pelican who used his engine hoist and the engine mounts:
Smoove1010
I had great luck with no drama using the small-drop method: drop the engine onto a dolly with the car low to the ground, then jack the car up side-to-side until the engine can be rolled out. I did this single-handed and there was never a moment of instability or lack of control.
Described here: 87 Drop Top - Drop-n-Top End I got the idea here: First Engine Drop The u-shaped base of my engine stand made the perfect dolly to drop the engine on to as well. I hope this helps! Good luck! GK
1987 3.2 911 Cabriolet Grand Prix White Exterior Five Shades of Burgundy Interior |
Member 911 Anonymous
Another way is to use a Motocycle Jack with platform extension and 1 x 18 x 24 piece of plank and basically raise from three points, engine, and HE's. Postioned forward to balance the gearbox and engine.
I personally like to remove the bumper to aid in the clearance.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Pinch,
For my drop I used a scrap of 2 x 6 cut to fit the width of the pan at the back edge. Jacked from the side. Bumper removed. HTH Thor ![]()
1978 SC coupe #1834 Last edited by Brown747; 01-05-2017 at 10:22 AM.. |
^^^ Nice.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 01-05-2017 at 10:30 AM.. Reason: 2nd look at pic :-P |
Thank you for the advice!
Thor; I'm trying to see exactly where you place the 2x6. Is it across the pan where the factory recommended jack points are? Like here: ![]() If so, does it sit on the welded seams or inboard of them? |
Yes...across the pan at area D in the red box. Placed right behind the edge of the pan. No risk of pan damage when using 2x6. Thor
1978 SC coupe #1834 |
